how do u get the switch off and back on it is the switch on the peddale
Mar 30, 2010 at 2:18 PM
BLUELIGHTNIN6
✓Experienced Mechanic
1.Disconnect the negative battery cable.
2.Disable the SIR system (if equipped).
3.Remove the clip (R/V Series) or unclip the switch (C/K Series) and unplug the electrical connector from the brake light switch.
4.Remove the switch.
5.Installation is the reverse of removal.
