1997 GMC C1500 1997 C1500 error code P01351
180,000 MILES • V8 • 2WD • AUTOMATIC
MANRR1967
error code P01351
What does this code mean?
Nov 20, 2008 at 1:20 PM
PEAR69
  • 1,482 POSTS
This code means ICM Ignition Control Circuit High Imput. This code seems to plague many chevy owners - especialy 1997 chevys. It could a bad ignition control module (ICM) - A ICM control circiut wire is shorting out - A bad or failing Power Control Module (PCM). I have even seen a loose fuel pump connection or a failing fuel pump send this code.
Is the engine running ok? Have you done any work to the fuel pump or gas tank lately?
This problem could also be a bad spark plug wire - cap - or rotor. If you change any ignition part especialy the plugs - plug wires - cap -rotor, Make sure you use A/C DELCO parts ONLY!! If you don't you'll be sorry...
Nov 20, 2008 at 3:44 PM
MANRR1967
It won't start, I have no spark and I haven't done any work on it.
Nov 21, 2008 at 5:35 AM
PEAR69
  • 1,482 POSTS
I suggest starting with the ignition control module. No spark is a classic case of this failure. However don't just replace it, test it or have it tested at autozone or a place like that. They will do this for free. Keep me posted.
Nov 21, 2008 at 3:58 PM
MANRR1967
good call it was the ignition control module, thanks
Nov 23, 2008 at 9:20 PM
PEAR69
  • 1,482 POSTS
Your welcome.
Nov 24, 2008 at 2:13 PM
