1996 GMC C1500 Car won't start
METALMAN1685
  • 1996 GMC C1500
  • V8
  • 142,000 MILES
Hello, I recently replaced the intake manifold gaskets on my 96 1500. I got everything back together okay but when I went to fire it up the engine turned over but didn't start. Had gas at rails but no spark at plug ends. I checked the wiring harness and all connections/grounds. I also checked for battery voltage at the coil, coil driver, and distributor, everything checked out okay. What else can I check?
Thursday, July 17th, 2008 AT 4:42 PM
Double check the camshaft and crankshaft positioning sensors
Thursday, July 17th, 2008 AT 5:58 PM
METALMAN1685
Thx for the reply. I checked all the connectors and sensors when it didn't fire the first time. I tested the ignition coil and everything checked out fine, what I am thinking is that when I installed the distributor into the motor, the gear spun and its off a tooth from where it was. Could this be causing the no fire from the ignition system?
Thursday, July 17th, 2008 AT 9:32 PM
What I am thinking is that when I installed the distributor into the motor, the gear spun and its off a tooth from where it was.
Even if the valve and ignition timing is off and the ignition system is good it will produce a spark-It'll probably combustion but won't start that's if you understand what I'm trying to say.
Friday, July 18th, 2008 AT 5:22 AM
