Hello, hope you got it fixed by now? Usually if the vehicle cranks good but won't start, I have a helper crank it, while I check for spark at the plugs. You can just pull a plug wire loose, use a known good plug or spark tester, ground to engine block, look for spark at the tip of plug, as the engine is cranked. If you have good spark everywhere, check fuel pressure.
If you have TBI fuel injection, you can see the injectors spray gas as the engine is cranked. Because there is a spray pattern, doesn't mean the pressure is good. You might also check for trouble-codes.
SPONSORED LINKS
Monday, April 13th, 2009 AT 3:39 PM
