1995 GMC C1500 car wont start
ROYBAL12
  • 1995 GMC C1500
  • V8
  • 153,000 MILES
Tried starting car this morning, but it wont switch over. Full tank of gas, brand new battery. Belts look fine and intact.
Thursday, August 6th, 2009 AT 11:31 AM
JDL
  • 16,098 POSTS
Hello, if your saying the starter won't crank, I'd still have to check that the battery has a full charge and that the battery connections are clean and tight on both ends. Have you tried cranking in neutral? You may have to check that the purple wire at the starter solenoid is hot, with the key in the crank position?
Thursday, August 6th, 2009 AT 11:45 AM
