1994 GMC C1500 WONT'T START AFTER ENGINE IS STARTED ONCE AN
B_RUEHLE
MEMBER
1994 GMC C1500
Electrical problem
1994 GMC C1500 V8 Four Wheel Drive Automatic
ENGINE STARTS AND RUNS WELL WHEN FIRST, STARTED COLD. AFTER 5 TO 10 MINUTES STALLS AND THEN WILL NOT FIRE. IS GETTING FUEL Into throttle body.
Sunday, February 8th, 2009 AT 3:40 PM
MECHANIC
Check if its getting spark if okay. Do a fuel pressure test
SPONSORED LINKS
Sunday, February 8th, 2009 AT 4:07 PM
B_RUEHLE
MEMBER
Lo again I shoud have given more info yes the truck has spark though it mighy have been week so replaced coil. New plugs, spark is there and fuel is working. I loosed the distributer to change advance. No differance. Us it possiby the converter is plugged there seemed to be smorking around the o2sensor in the manifold thanks
Tuesday, February 10th, 2009 AT 10:37 PM
MECHANIC
Do a backpressure test on the exhaust system to rule out the catalytic converter
