1990 GMC C1500
250,000 MILES • V8 • 2WD • AUTOMATIC
I6LIKE6MY6TRUCK6
[img:eb7eea9644]http://www.2carpros.com/forum/automotive_pictures/336677_mytruckfeb2009a_1.jpg[/img:eb7eea9644]
my service engine soon light is coming on while i drive. how do i check the codes myself? do i need a special tool or something? please be specific. i'm very new to this.
Mar 26, 2009 at 1:39 PM
OBXAUTOMEDIC
  • 3,717 POSTS
To extract a trouble from the computer for diagnostic purposes, the Assembly Line Communication Link (ALDL) connector is used. Ground terminals A and B with the ignition "ON" and engine not running. The system will enter the diagnostic mode. In this mode, the computer will display a 12, three consecutive times, by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" or light. A 12 consists of one flash, a short pause, then two flashes in rapid succession. After 12 is displayed, any stored trouble s will be displayed by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" light. All s are displayed 3 times each then a 12 will repeat. In the diagnostic mode, the computer will also energize all computer controlled relays and solenoids.
https://images.2carpros.com/forum/automotive_pictures/188069_95bonnevillealdl_connector_2.gif
13 Open Oxygen Sensor Circuit 14 Coolant Sensor Circuit Shorted 15 Coolant Sensor Circuit Open 21 Throttle Position Sensor (Signal Voltage High) 22 Open Throttle Position Sensor Circuit 24 Vehicle Speed Sensor (VSS) Circuit 32 Exhaust Gas Recirculation System (Over 8500 GVW) 32 Exhaust Gas Recirculation System (Under 8500 GVW) 33 Manifold Absolute Pressure Sensor (MAP) Voltage High) 34 Manifold Absolute Pressure Sensor (MAP) Voltage Low) 35 Idle Air Control (IAC) System 42 Electronic Spark Timing (EST) Circuit 43 Electronic Spark Control (ESC) Circuit 44 Oxygen Sensor Circuit Lean Exhaust Indicated 45 Oxygen Sensor Circuit Rich Exhaust Indicated 51 Faulty Mem-Cal or PROM Problem 52 Fuel CALPAK Missing 53 Over Voltage Error 54 Fuel Pump Circuit (Low Voltage) 55 Faulty ECM
Mar 26, 2009 at 2:26 PM
MNO221
  • 49 POSTS
Code 43 for trucks with a 4L60E & 4L80E is
Knock Sensor.
Code 43 for trucks w/o the above tranny is
Electronic Spark Control Circuit.
Which is correct ?
Mar 27, 2009 at 3:01 PM
OBXAUTOMEDIC
  • 3,717 POSTS
[quote:e32776d7ca="mno221"]Code 43 for trucks with a 4L60E & 4L80E is
Knock Sensor.
Which is correct ?[/quote:e32776d7ca]
If it were the ESC Circuit you vehicle wouldn't start.
Also do you know if it is a 3 or a 4 speed the 4 in the 4l indicates a 4 speed tranny.
Mar 27, 2009 at 4:19 PM
MNO221
  • 49 POSTS
Yes, my tranny is a 4 speed....
Lloyd
Mar 28, 2009 at 2:32 AM
OBXAUTOMEDIC
  • 3,717 POSTS
So most likely it is your knock sensor and not the ESC.
Mar 28, 2009 at 2:55 AM
