Glowing catalytic converter and fuel problem
210,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
CJBORING
My son has a 1999 Hyundai elantra that started acting really sluggish about a month ago. I noticed it had an exhaust leak and we looked at the front cat ( they have 2) and it was glowing red hot. The flexible exhaust pipe connected to it was glowing red hot and torn in half, hence the leak. First thought was back pressure from lower cat. Had to replace upper car and flex. Did that and started car. Car started fine and sounded great for about 5 minutes. Noticed lots of white exhaust and fuel smell. Looked at new cat and of course it was glowing red hot. Looked at spark plugs. Two of them looked fouled with strong gas smell. Changed those and fired car up. Again sounded great for 5 minutes. Again cat starts to get hot. Thinking upstream o2 sensor or fuel pressure regulator. Everything i read leads me to believe there is too much fuel being burned in catalytic converter. Please help. Have good mechanic skills but diagnosing this is testing my limits.
Jan 19, 2015 at 8:12 AM
  • 110,251 POSTS
Do you have access to a live scanner that can tell you fuel trims, coolant temp sensor readings, O2 sensor readings... ?
Jan 19, 2015 at 9:03 PM
CJBORING
No I have no access to any of that right now. I live in a remote area and have to drive into town for any parts. Wish I would have taken it to a shop for at least a diagnosis. Now I dont trust it to make it into one. Might have to get ot towed or something. After replacing exhaust and cat, plugs and air filter it still had no power and the exhaust smelled like gas bad. Im leaning to the fuel system: injectors, regulator, etc. still havent a clue though. Thanks for any help.
Jan 19, 2015 at 9:32 PM
  • 110,251 POSTS
I agree with you and feel it is a fuel related issue. However, it could be caused by a faulty sensor, a bad fuel pressure regulator, a leaking injector... Have you checked fuel pump pressure?
Jan 21, 2015 at 12:33 AM
