1995 Geo Tracker clutch
JIMINI101
  • 7 POSTS
Drive Train Axles Bearings problem
1995 Geo Tracker 4 cyl Four Wheel Drive Manual 220 k miles
My clutch keeps acting up, seeems like the cable keeps stretching.
I adjust the clutch cable and slowly the clutch misadjusts. after a bit of driving (few km) the clutch will not fully disengage. After a while I have to shut the ignition off, put it in first gear, clutch in start car it lurches fwd. It doesn't completely disengage.
If the clutch was wearing out wouldn't it start slipping?
It behaves as if the cable adjusting lock nut is turning back out.
Is it possible for the cable to stretch for some reason?
I replaced rhe clutch a couple of years ago(aftermarket)
Jul 21, 2009 at 4:47 AM
  • 110,248 POSTS
Actually, I doubt the clutch cable would be stretching that quickly. To me it sounds like a bad pressure plate. Does the problem seem to happen after the engine is warm or does it do it cold too? IF the springs in the pressure plate are weak, the problem will get worse the warmer it gets. As far as a bad clutch, they don't always slip, and the clutch disc isn't always the problem.
Jul 21, 2009 at 5:01 PM
JIMINI101
  • 7 POSTS
Yes the clutch problem happens after the vehicle warms up, Thanks for your quick reply..Jim
Jul 21, 2009 at 5:25 PM
  • 110,248 POSTS
Jim:
Based on your description, I have a feelng the pressure plate is weak.
Jul 22, 2009 at 4:43 PM
JIMINI101
  • 7 POSTS
Well I've installed a new Exidy clutch, seem OK I'll give it a longer run to see if it's OK.
The Exidy feels smoother, Thanks again, I'm 78 and crawling under a car with a homemade transmission jack isn't the easiest thing to do. I don't know if I'll be able to do this stuff when I get old. lol Jim
Aug 12, 2009 at 6:07 PM
  • 110,248 POSTS
I hope I can do it at 78. At 45, I feel like I'm dieing.
Aug 13, 2009 at 5:45 AM
JIMINI101
  • 7 POSTS
OH! OH! the new clutch started doing the same thing again.Think I'll try replacing the cable . The parts dealer suggested it might be the firewall giving some when it's warmed up.
Aug 27, 2009 at 5:31 PM
  • 110,248 POSTS
I question that, but stranger things have happened. Let me know the outcome.
Aug 28, 2009 at 5:59 AM
JIMINI101
  • 7 POSTS
I changed the cable, don't think that was the problem.
There is no way I believe the firewall flexes,but and this is a big BUT, while I was under the car I noticed that the heat shield on the exhaust before the catalytic converter, had deteriorated away next to the clutch housing.
The temperature has been in the 30's (C) and with some spirited driving, I think the housing got too hot,I put some heat shield (dryer exhaust) over that part of the exhaust, to see if that will make a difference.
The way I see it, you were correct in the heat on the pressure plate.
Hope I've learned something in the process.lol
Thanks again, we live and learn (I hope)..Jim
Aug 28, 2009 at 4:27 PM
  • 110,248 POSTS
Jim:
That is great news. Let us know if you have questions in the future, and thanks for using 2carpros.com.
Aug 28, 2009 at 4:55 PM
