1992 Geo Tracker Clutch has gone soft and car won't shift u
1992 GEO TRACKER
KAI DARIUS KOHL
Transmission problem
1992 Geo Tracker 4 cyl Two Wheel Drive Automatic 100k miles
My 92 geo trackers clutch has gone soft and i can only shift into gears when the car is off or at the exact moment (around2-3k rpm,) when u can shift without using a clutch... Any ideas?
Oct 3, 2009 at 10:50 AM
Try bleeding the clutch slave don't work replace the clutch assembly
Oct 3, 2009 at 10:53 AM
KAI DARIUS KOHL
it is not a hydraulic clutch and I could not find any information on bleeding the clutch for this car. I saw a note in my service manual about setting the amount of play the clutch pedal has, could that be causing this problem? thanks again.
Oct 3, 2009 at 9:36 PM
I see -okay just follow the procedures on adjusting the clutch free play as indicated in the repair manual to include the pedal height.
Oct 4, 2009 at 4:57 PM
