Hello. You were recomended by a friend as having given her great advice.
I have a 92 Geo Tracker that I have replaced the clutch, pressure plate, throwout bearing, slides and clutch cable on. However, the clutch continues to tighten up becoming harder to push to the floor and eventually making shifting almost impossible. I initially replaced the (failing) clutch with a heavy duty one from CenterForce. When it started to bind again, we removed the weights as they seemed to be binding on the throwout bearing. When that didn't fix the issue, we went back to a new oem pressure plate and clutch. It lasted about three days without binding and then after adjusting the new cable, made it to the evening of the same day before I was unable to properly shift.
My mechanic and I are both stumped on this issue. Any advice would be greatly appreciated.
Thank you,
Eric
Thank you,
Eric
Dec 14, 2009 at 4:45 AM
