1995 Geo Tracker
165,000 MILES • 4 CYL • 4WD • MANUAL
REKNAT
will crank over fast but no spark from coil to the distributor . Replaced coil now have good spark to the distributor but no spark to the spark plugs. conected test light to spark plug wire and still no power to light. cleaned inside distributor cap very little light grey build up and cleaned the rotor cap. I checked the igniter like the haynes repair manual said to use two 1.5 volt batteries @ a ohmmeter @ tested good. can it be problem with the pick-up or ecm and is there a way to check these or could it be somethink else. please let me know thanks donnie. I do appliance repair so if you have any questions plese let me know if I can answer them I will. thanks again.
Nov 7, 2009 at 12:45 PM
RICHARDRIGER
Hi: Did the Tracker just die ? or failed to start after repair work ? Check for short in distributor rotor to shaft or proper dist. cap fit and lock down if it shows no "tracking" inside r riger
Nov 15, 2010 at 2:14 PM
