1990 Geo Tracker Car won't start
RETIRED57
Engine Mechanical problem
1990 Geo Tracker 4 cyl Four Wheel Drive Manual
How can I find out if a timing belt is working without removing the guard. The car ran jn 1st gear and when I put it into 2nd it lost power.I put it back in 1st and it ran. Then I shut it off,and now it won't start. It turns over OK.
Thank you
Clint
Oct 21, 2009 at 10:11 AM
  • 75,988 POSTS
If its a distributor driven ignition system remove the distributor cap and have a helper crank engine over while you look if the rotor is turning if not its gone
Oct 21, 2009 at 10:37 AM
