1994 Geo Prizm Chirping Grinding Noise
KLEIKER
My mom drives a 1994 Geo Prizm. It has approximately 164K miles on it. On Friday it started making a weird noise out of the blue. It only makes the noise when she steps on the accelerator (and she has to be accelerating to speeds greater than 5-10 mph) and we are wondering if it could be the belts that need to be replaced--or something more. It sounds like a bird chirping noise and a grinding noise mixed together. Any ideas?
Thanks.
Oct 8, 2007 at 5:02 AM
MERLIN2021
  • 17,250 POSTS
Take a look at the belt tensioner pulley, and the idler if it has one, remove the belt and spin them with your fingers, they should feel smooth and rotate freely, if there is any binding or woble...sideplay, replace them and the belt!
Oct 8, 2007 at 7:18 AM
Suggested Repair
Inspect the belt tensioner pulley and the idler pulley if equipped. Remove the belt and spin the pulleys by hand; they should turn freely and feel smooth. If either binds, wobbles, or has side play, replace the pulley(s) and the belt.
Conversation Summary
A 1994 Geo Prizm with about 164,000 miles began making a chirping and grinding noise only when accelerating above roughly 5-10 mph. The owner wondered whether the belts needed replacement. The expert advised checking the belt tensioner pulley and idler, spinning them by hand with the belt removed, and replacing any pulley that binds or has side play along with the belt.
