1992 Geo Prizm Valve Clicking Noise
There is s special tool you would need (Kent-Moore J-37141-A) to adjust the valves. You remove the cam cover, insert one of the tools (it is a set) to compress the valve spring, use the other tool to hold it and then replace the shim.
The problem sounds like they adjusted them hot and when it cooled down the adjustment was off.
I would have them do it until they get it right (without charging you).
Suggested Repair
Have the 4AFE valves readjusted cold with the correct shims and the required special tool, at no charge if the prior hot adjustment was wrong. If the largest shim still cannot meet spec, the cam or bearing caps may need replacement. If wear exceeds what adjustment can correct, a quiet-lifter additive can be tried in place of one quart of oil.
Conversation Summary
The owner of a 1992 Geo Prizm with a 4AFE reports valve-train clicking that remained after a dealer adjustment done on a hot engine. The owner believes a correct cold adjustment should eliminate the noise. One expert agrees but notes wear can exceed available adjustment and suggests a quiet-lifter additive. Another says 4AFE valves must be set cold with shims and a special tool, that a hot adjustment would be off when cold, and that the shop should redo the job free; if the largest shim cannot meet spec, the cam or bearing caps may need replacement.
