1994 Geo Prizm 1994 Geo Prizm Scraping Sound Only When Acce
CONDENSER
1994 Geo Prizm 4 cyl
Hello! I have a 1994 Geo Prizm which makes a scraping sound, but only when I accelerate. It is coming from the front of the passenger side of the car only. It only makes this sound when I accelerate. I have new brake pads (were put on today) and changed the oil (less than 5 miles on the new batch of oil).
My friend took a look at my car. It sounds like there is squealing under the CV boot. There is a lot of noise coming form the CV joint on the right side. He thought it sounded like rubber on rubber, but it sounds like scraping to both my Dad and myself.
Oct 9, 2009 at 6:41 PM
MMPRINCE4000
  • 8,548 POSTS
Try this first:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Also is this a 3 speed auto or 4 speed, or manual?
Oct 10, 2009 at 1:03 AM
