1994 Geo Prizm oil leak
1994 GEO PRIZM
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
DOITJEWETT
I put oil in the car an it just runs right out
Feb 13, 2008 at 5:57 AM
MMPRINCE4000
  • 8,548 POSTS
Is your drain plug in? :D
You can take the car to most repair shops and they will add a substance to the oil, you drive the car for 150 miles, then they look at the engine with a blacklight to isolate the leak.
Usually, front and rear seals, oil pan, valve covers, cam seals, distributor seal, spark plug tube seals etc.
The real expensive one is the rear main, since the transmission must be removed.
Feb 13, 2008 at 9:26 AM
