1994 Geo Prizm fuel pump not getting enough volts
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
JESSLUNA210
i changed the fuel pump and it doesnt want to start now. i exchanged fuel pump and it still wouldnt start. i checked all relays and fuses w/ a meter and are all good. im getting 12 volts all the way to my gauges and then only 3 volts after that. is it the wire?
Aug 28, 2010 at 7:22 AM
  • 75,988 POSTS
Voltage drop problem-start checking the wires and also the fuel pump relay
Aug 28, 2010 at 11:51 AM
JESSLUNA210
i did check the wires and they r all intact.
Sep 4, 2010 at 5:39 AM
