1990 Geo Prizm 1990 Geo fuel pump location
1990 GEO PRIZM
100,000 MILES • 4 CYL • FWD • AUTOMATIC
PEEGEEZ
Need help to locate fuel pump on 1990 Geo Prism. Fuel injected. Haven't looked for it yet. Checked the relay etc. all good but still no fuel pressure. I want to change out the fuel pump and filter.
Thanks
Apr 18, 2008 at 10:55 PM
MMPRINCE4000
  • 8,548 POSTS
The pump is in the tank, so the tank would have to be removed or lowered.
To check the pump, jump terminals +B and Fp at the ALDL on the left front shock tower, if the pump runs then it is a fuse or relay.
The filter is accessed by removing the left stone guard and wheel, you can see it through the steering arm hole.
Apr 19, 2008 at 4:53 AM
PEEGEEZ
Thank You very much
Apr 19, 2008 at 5:56 PM
