1994 geo prism stalling out
1994 GEO PRIZM
MAGREDVETTE
hey , i have a 1994 geo prism 109000miles . It will run fine for anywhere from 5-40 min then quit with no warning. even at 70 mph. then will not start until engine cools down a little 10-20 min. replaced cap,rotor ,plugs,wires,coil,module and distributor. also tried new ecm. code 12 keeps coming up, dist,ecm or camshaft sensor(no sensor listed for this car). any ideas? when car dies no spark. thanks
May 29, 2007 at 2:46 PM
2CARPRO JACK
  • 11,533 POSTS
Now the fun begins.........Sounds like it may be time for a pin-topin Ohms test of the wiring to the ECM. Might have a bad connection or bad wire. Thye cam and crank position sensor are one in the same
May 30, 2007 at 7:47 AM
