1993 Geo Prizm car died
NEWFRIEND328
  • 1993 GEO PRIZM
  • 4 CYL
  • 120,000 MILES
Car died while on the interstate. Got it home no spark at plugs. Replaced ignition coil plugs and wires andf rotoe cap. Battery good and I have power at the rotor cao and coil. There is a capasitor should this be replaced and going to check to make sure timing belt did not break. Can you think of anything else I should try?
Friday, November 6th, 2009 AT 7:36 AM
MMPRINCE4000
  • 8,548 POSTS
The capacitor is a filter that removes interference with TV and radio.
Most likely you have a bad ignition module (ignitor).
Doubtfull timing belt broke, although exhaust camshaft turns dist.
Rotate engine a few inches and watch rotor, if it moves, then belt is OK.
If not, then belt is broke and possible damage to valves and head.
Saturday, November 7th, 2009 AT 5:26 AM
