1990 Geo Prizm starting problems
MARQDOGG
  • 1990 GEO PRIZM
  • 4 CYL
  • FWD
  • 204,000 MILES
Lets say I have been driving all day when it is very hot. When I cut the car off every now and then the car wont start. The lights on the dash board come on but the car wont crank at all and if I leave it there for like an hour it will eventually crank over or if I get a jump or use the jump starter it will crank over. I have changed the battery/ alternator and I have tightened the battery cables very tight so can anyone help me with this problem thank you.
Wednesday, May 27th, 2009 AT 9:44 AM
MMPRINCE4000
  • 8,548 POSTS
You may have a lot of resistance in the battery cables. Measure voltage at starter cable, if less than battery voltage, you may need new cables.
Another possibility is the ign. Switch.
Saturday, May 30th, 2009 AT 6:44 AM
