1990 Geo Prizm Overheating
A head gasket replacement at a dealer will generally run $800 or more. If the head is warped they will probably replace it, add about $1,000.
You could buy a used engine at a junk yard for $5-600, but you will most likely never find one with 17,000 miles.
Best advice is to call around and get estimates.
The cost to replace would depend on who does it. A dealer would be more expensive. If you can find a local garage they would likely be cheaper.
I would guess you would be talking at least $1,000 in any case.
Suggested Repair
If there is no coolant in the oil and the cylinder head is not warped, replace the head gasket. If coolant has mixed with the oil or the head is warped, an engine replacement is the better option. Get local estimates; dealer head-gasket work is often about $800 or more, plus roughly $1,000 if the head must be replaced, while engine replacement labor is typically at least $1,000 and a used engine may cost about $500 to $600.
Conversation Summary
The owner of a 1990 Geo Prizm with about 100,000 miles reported overheating and suspected a blown head gasket after an earlier radiator replacement. They asked whether to repair the gasket or install a rebuilt engine and requested cost estimates. The expert advised a head-gasket repair only if coolant has not entered the oil and the head is not warped, because coolant in the oil can damage bearings. Otherwise, engine replacement is preferable. Quoted ranges were about $800 or more for a dealer gasket job, about $1,000 more for a warped head, roughly $500 to $600 for a used engine, and at least $1,000 for replacement labor, with a local shop likely cheaper than a dealer.
