Chevy Metro melting wire when starting engine - HELP
METROQUESTIONS
I have a 1998 Chevy Metro, 3cyl, 1.0 with mileage: 115,000. When starting the engine there is an intermittent problem with the ground wire from the ignition coil to the engine block getting hot and melting the plastic insulation. When this happens the engine will not start. I have disconnected the air conditioning fan wire (No AC anyway) and replaced the ignition coil. Normally the car starts fine but every once and awhile this problem still occurs on a random basis. I have temporarily replaced the ground wire with one of heavier gauge copper. When I replace the wire I can usually start the car and the problem disappears, until the next time. It seems to be more frequent when first starting the car in the morning. Please help me with this strange problem. Thanks
Sep 4, 2007 at 12:17 AM
GFIMOTORCARS
  • 673 POSTS
You are getting too much amperage to this wire. Check your fuses and make sure they are rated correctly for this component. If a too high of amperage fuse is installed this could cause this problem.
Feb 27, 2009 at 11:28 AM
