1997 Geo Metro starting
1997 GEO METRO
69,000 MILES • 4 CYL • 2WD • AUTOMATIC
MELONYROSE
My daughter drove her car to a local restaurant, turned the car off and went inside. When she returned, the car would not start. There is power to the ignition, starter was removed and tested and is ok. Fused checked and ok. Any ideas? Oil and coolant levels normal.
Mar 20, 2009 at 11:47 AM
My question is -Is it cranking over and refuses to start or just won't crank at all/nothing?
Mar 21, 2009 at 12:19 AM
MELONYROSE
Thanks for responding. After much troubleshooting, I found that the battery cable was so corroded down into the covering. I stripped it and reconnected and then it turned over. Wasn't getting enough juice to turn over the starter. Thanks again for the attention!!
Mar 21, 2009 at 7:16 AM
