HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Geo
Metro
Engine Cooling
Water Pump
1995 Geo Metro
ANDERSON_920
MEMBER
1995 GEO METRO
4 CYL
FWD
MANUAL
82,000 MILES
How do you know if your water pump is bad?
Friday, November 7th, 2008 AT 5:06 PM
MECHANIC
Hi there, normally it will leak water from the vent hole or it will be noisy, for pumps that are belt driven and not that easily seen, water leaking from under the front cover is a good indication as to if the pump is bad or not.
Mark (mhpautos)
Friday, November 7th, 2008 AT 10:31 PM
Please
login
or
register
to post a reply.
Related Water Pump Content
How Do I Cange The Water Pump
Asked by
Anonymous
2 IMAGES
1993
GEO METRO
GUIDE
Water Pump Symptoms
The water pump is designed with a weep hole to allow coolant to leak from its housing before it can reach the shaft bearing which will cause the shaft to lock up and stop...
1995 Geo Metro 1995 Geo Metro Leaking Coolant
My 1995 Geo Metro Temperature Gauge Stopped Working A Few Weeks Ago (it Constantly Shows No Temp). I Drove It To Work The Other Day And...
Asked by
chucky486
1 ANSWER
1995
GEO METRO
1995 Geo Metro Radiator Fan Problem
Electrical Problem 1995 Geo Metro My Radiator Fan Does Not Seem To Be Working Right, As It Does Not Start Spinning When I Start My...
Asked by
magic.sean
1995
GEO METRO
1995 Geo Metro
I Broke Off The Bolt For The Thermostat Housing. Where Can I Find New Bolts? Just So You Know. The Thermostat Is Located Under The...
Asked by
edster812
1 ANSWER
1995
GEO METRO
1996 Geo Metro Slow Coolant Leak
Engine Cooling Problem 1996 Geo Metro Two Wheel Drive Manual 140k Miles 3 Cyl. 5-speed Engine. Sometimes Leaking Clear Coolant At...
Asked by
Gramma Lynne
1996
GEO METRO
VIEW MORE
How to Replace Water Pump Ford F-150
Water Pump
Water Pump Replacement
