1997 Geo Metro rotors
TOWTRUCK76825
  • 1997 GEO METRO
Brakes problem
1997 Geo Metro Engine Size unknown Front Wheel Drive Automatic 189562 miles
How do I remove the front rotors on a 1997 geo metro?
Sunday, March 9th, 2008 AT 12:02 PM
GFIMOTORCARS
  • 673 POSTS
You will need to remove the two bolts that hold the caliper assembly on. Once these are removed the rotors should come right off, however often times you will need to hit them with a heavy hammer on the outer edge to break them loose from the hub.
Friday, February 27th, 2009 AT 7:47 PM
