1996 Geo Metro running hot
1996 GEO METRO
14,000 MILES • 4 CYL • 2WD • AUTOMATIC
MRSDSGEORIA
HI OK THIS WHAT I AM ASKING MY GEO RUN HOT I CHANGE THE THERMOSTAT AND THE FAN DOES RUN BUT WENT YOU COME TO A STOP OR AT A RED LIGHT IT SEEM TO GO TO THE RED IS IT THE WATER PUMP OR IS IT THE RADIATOR PLEASE HELP ME BECAUSE I LOVE MY CAR AND DO NOT WANT TO MESS IT UP PLEASE HELP.
Jun 15, 2010 at 9:29 AM
Open up the radiator cap and have helper start the car while you look inside the opening -do you see the coolant squirling around if so have the helper increase engine speed did the coolant flow increase if so the water pump is okay-On the radiator while engine is idling feel the radiator for cold spots could also be airlock try bleeding it, if it continues get it block and pressure tested.
Jun 15, 2010 at 9:58 AM
MRSDSGEORIA
IT GOING OK IN THERADIATOR IT COME OUT IN THE RECOVERY AND IT COME OUT BOILING VERY HOT
Jun 15, 2010 at 10:06 AM
