Gear shifter
1995 FORD ESCORT
175,000 MILES • 4 CYL
GEORAIN
Pulling away from in first year I barely get twenty miles an hour and when I put it into second gear it's like it doesn't catch second gear and it revs up RPM's two like four thousand three three and four thousand and then it catches. It only goes about thirty and second gear third gear. it'll get up to about 5 it's just slow going. tonight it is slipping. I guess is what everybody tells me I understand I can adjust the clutch but it feels like my gear shifter is too loose?
Dec 27, 2018 at 5:09 AM
  • 110,244 POSTS
It sounds like what the others have told you, the clutch is bad. This vehicle has a hydraulic clutch system which is not adjustable. When it slips, there nothing that can be done other than replacement.
I wish I had better news, but that's what it sounds like the problem is.
Dec 27, 2018 at 7:35 AM
GEORAIN
OMG, no! How much could that run me?
Dec 27, 2018 at 9:12 AM
  • 110,244 POSTS
Hi and sorry for the news. However, it sounds like that is what is happening. Don't laugh, but the easiest way to determine if the clutch is bad is a simple trick I was taught years ago. In an area that it is safe, place the transmission in fifth gear. Give the engine some gas and let out the clutch. If the engine doesn't stall, replace the clutch. Sounds crazy, but a good clutch will cause the engine to stall.
As far as price, I don't know where you live and what the going rate is for labor. However, I can tell you the book calls for hours in labor for the job. So, multiply shop rate by that number to determine approximately what the labor should cost.
Next, in addition to replacing the clutch, the pressure plate and throw out bearing should be done at the same time. There should be no additional labor because these parts come out with the clutch disc. What to do is call local parts stores and tell them you need a price on a clutch set for your vehicle and confirm that the price they quote you includes the aforementioned parts. Again, I don't know where you are located, so prices will change. If you were here (Pittsburgh, PA) you could expect to pay under $150.00 dollars. I just looked one up on line and the entire set (aftermarket from a nationally recognized parts store) started at $102.00 for everything.
Let me know if I can help of if you have other questions.
Dec 27, 2018 at 1:20 PM
