Gas mileage reduction from 25mpg to 20 mpg
2001 TOYOTA SIENNA
175,000 MILES
PIPPISMOM
Until August 2013, my Sienna got 25mpg across all driving for the 7+ years ant 125,000 miles I have driven it. In August, I had a dealer replace the IAC motor, throttle body gasket;, and idle speed valve assembly. The car now gets 20mpg across all driving -- 5mpg less, over the 3500 miles I have driven since then. The dealer says it must be due to weather conditions or driving changes, none of which apply of course. They are totally uninterested in helping the gas mileage problem, Any suggestions?
Oct 28, 2013 at 3:33 AM
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge first. Then check for a vacuum leak like a hose off, cracked or broken vacuum line etc.
Oct 28, 2013 at 5:01 AM
THIS IS MIKE
  • 686 POSTS
Also check the air intake boot for a complete seal and make sure there are no leaks. Un-metered air could cause the computer to adjust the timing and amount of fuel that is being used causing poor mileage.
Oct 28, 2013 at 7:47 AM
PIPPISMOM
Both suggestions sound worthwhile to investigate. Will do with my local mechanic and thanks very much. Any other suggestions also welcome! I appreciate you all's help!
Oct 29, 2013 at 1:25 AM
ANONYMOUS
  • 0 POST
Too add, gas companies change their mixture to a less potent fuel because in lower temperatures pinging is a lesser problem. This sometimes effects mileage.
Nov 6, 2013 at 12:33 AM
HMAC300
  • 48,601 POSTS
one other thing I forgot to add especially about this is if you use or can use fuels like E85 which means 85% alcohol and 15% gas then your mileage will suffer 25% if you use the 15% alcohol which is pretty prevalent out west in u.s your mileage will also suffer. so look at the pump when you start to gas up use only the 10% fuel mix.
Nov 6, 2013 at 12:38 AM
