Fuse keeps blowing
230,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
VERNON MARVEL MOORE
My 7.5 fuse keeps blowing on my car xTE model. I believe it is for the dome interior light, dash clock, and the seat belt warning. Also, wireless key-less remote do not work.
Things that do work:
Cigarette lighter.
Headlight (with Daytime Running Light).
Key reminder.
Moon roof.
Theft deterrent.
The fuse never last more than maybe a month. I am trying to find solutions. It is likely a short somewhere or maybe a grounding wire. Do you have any suggestions or help you can offer please? And thanks!
May 23, 2018 at 3:35 PM
CARADIODOC
  • 34,414 POSTS
A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a twelve volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it is not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
For intermittent problems like yours the bulb may be dim already. Watch what takes place when it gets bright. That is when the short is occurring. It could be due to the rocking of the engine when you shift between reverse and drive. It could be due to the body flexing when you drive over bumps in the road. The bulb limits current to a safe value when the short occurs, in this case about one amp. The circuitry is likely to not work properly with a brake light in the circuit because it limits current too much, Try a headlight bulb instead of the brake light bulb. The low beam filament will limit current to five amps, and the high beam filament will allow about six amps to flow.
With no other observations to go on yet, may I suggest that a lot of blown fuses are caused by charging phones and things like that from the cigarette lighter socket. While they will work, those are designed with special contacts for lighter elements. Often the regular contact on the side of the plugs will touch the safety cutout contact if that plug is inserted just right. You will see the test bulb get bright when you insert the charger plug if that is what's causing the blowing fuse.
May 24, 2018 at 11:27 AM
