Remove the battery to get it out of the way, remove the two bolts holding the fuse box, the bottom of the fuse box comes off by depressing on each side near the bottom, locate the large black and white wires that go into the fuse, you'll need a screw driver to un-lock the fuse and fuse holder, pulling slightly on the wires while depressing the latch, it should come out from the bottom, the two wires are bolted on to the fuse, remove the bolts and the fuse should slide out of the fuse holder, install new fuse, bolt the wires back in place, insert the fuse and fuse holder back into the fuse box, replace the bottom of the fuse box, rebolt to the car, re-install battery.
SPONSORED LINKS
Monday, May 10th, 2010 AT 11:41 AM
