Fuel tank filler neck replacement
100,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
TURPEN36
How do I change the filler neck on the car listed above? Do I have to drain the gas?
Apr 7, 2020 at 5:31 PM
STEVE W.
  • 15,394 POSTS
You will want to run it to about a half tank or so, then jack it up in the rear. The filler neck is easy to change as it's pretty much out in the open. There are the three screws you can see in next to the cap and most have a couple small brackets that hold it to the body near the clamp for the EVAP pipe but they can rust off depending on the area you live. The hardest part is removing the clamps that secure the hoses.
Apr 7, 2020 at 6:36 PM
