1995 Chevy Lumina Fuel tank strap replacement
1995 CHEVROLET LUMINA
BRH1970
1995 Chevy Lumina
Is it necessary to drop the fuel tank when replacing the fuel tank straps?
Nov 22, 2009 at 8:17 AM
  • 110,240 POSTS
You should be able to replace them without removing the tank. Do one at a time, and support the tank so it doesn't move when you remove the strap.
Let me know if you have other questions. Also, spray down the retaining bolts with a penetrating oil several times before trying to remove them. Chances are they are rusted and you don't want them to break.
Dec 5, 2009 at 1:05 PM
