1997 Chevy Lumina gas tank leak
1997 CHEVROLET LUMINA
154,000 MILES • 6 CYL • 2WD • AUTOMATIC
BILLSFANTONY
Gas tank leaks by filler neck. Can the filler neck be replaced without changing the whole tank?
Nov 17, 2008 at 12:29 AM
BLACKOP555
  • 10,386 POSTS
tank or the rubber part of the filler hose?
if its on the tank you can use some stuff called
"seal-all" you just slap that stuff on there as per directions and youll never have to worry about that leak again.
Nov 17, 2008 at 1:18 AM
