Also, so long as I ground pin #6 on the EEC test connector, the pump will run all day.
We know the results of that test mean: I am getting power from EEC power relay to fuel pump relay coil, from the Fuse link at starter solenoid to fuel pump contacts common pin, from the ignition swith to EEC power relay coil, also that the fuel pump and EEC power relays are OK, Inertia swith is OK, selected fuel pump is ok, wiring and plugs are ok from fuel pump relay to pumps, ground for pumps is OK, and I am getting power from Ignition switch to EEC Power Relay Coil. Also, the test bypasses the EEC computer. That is why I replaced the EEC computer. So why does it work when grounding that pin only? (And could it be the Stater bad?)
SPONSORED LINKS
helpful?Yes
Monday, January 18th, 2021 AT 5:44 PM
(Merged)
