When decelerating the engine bogs down
90,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
SPITFIRE13
  • 6 POSTS
My fuel rails are held in place by plastic hooks or something similar and one of the hooks broke and now the fuel rail is hanging by one hook. would that cause my cars engine to bog down and just about shut off when ever I brake to slow down or even when I'm driving at low speeds?
Mar 1, 2020 at 4:54 PM
That is unlikely. If this was going to cause an issue it would most likely be a fuel leak.
This could be a fuel pressure issue but we need to monitor it and see what we have. Do you have access to a fuel pressure gauge and are you able to do this work?
If so, here is a guide that we can run through. If we can confirm this is fuel related then we can go further. If it is not then there are other things we can do but the most likely cause of this is low fuel pressure.
Other possible causes of this would be vacuum leaks, ignition issue, or air flow issues including sensor issues. Again, we can work through all this but we need to eliminate fuel first. Thanks
Mar 1, 2020 at 11:03 PM
SPITFIRE13
  • 6 POSTS
I've checked the fuel system and everything checked out, the car is mainly showing signs of rpm going below 500 when I'm coming to a stop, the transmission not shifting right and my power steering jerking when I'm trying to steer at a stop, but the only problem that still shows up when I'm moving would be the transmission shifting hard.
Mar 4, 2020 at 4:59 AM
Okay. Have you checked for codes. I suspect you have a possible solenoid issue but if that is the case we should have some codes that support that. Either way, codes or no codes, will point us in a direction. If you cannot pull codes, then most parts stores are able to do that for you fee of charge.
Mar 4, 2020 at 8:34 AM
SPITFIRE13
  • 6 POSTS
The only code that shows up is thermostat but that one I already know about.
Mar 4, 2020 at 8:44 AM
SPITFIRE13
  • 6 POSTS
Unless a solenoid or otherwise can go bad without bringing up any codes.
Mar 4, 2020 at 8:45 AM
Okay. So if you have no codes and have a harsh shift then that means the transmission is doing what it is supposed to do but something mechanical is causing the harsh shift. Most likely it is the fluid but we could have an issue with the clutches in the transmission. Do you know if it is the same shift point each time that is harsh or is it all of them or varies?
Have you checked the fluid for level and condition?
Mar 4, 2020 at 9:19 AM
SPITFIRE13
  • 6 POSTS
I'll have to get the fluids checked then as the harsh shift is the same 2 gears which are second and third gear, but doesn't shift hard above 2,500 rpm's. I'll get the fluid levels checked.
Mar 4, 2020 at 9:25 AM
Okay. That is good info. Yes. Let's start with fluid. However, the other possible cause would be low pressure so we may need to monitor the pressure when this happens. The fact that higher RPM's doesn't do it shows that when the pressure is higher it shifts properly.
Let me know what you find with the fluid and we can go from there. Thanks
Mar 4, 2020 at 9:43 AM
