Location fuel pump relay
GARY14
  • 1999 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 177,000 MILES
Looking for location of fuel pump relay?
Thursday, January 7th, 2010 AT 3:57 PM
The relay you're looking for is the circuit opening relay which is located in the engine compartment in relay box no.1 Here is a guide to help check it with the diagrams of the location below.
Thursday, January 7th, 2010 AT 7:32 PM
TEXACA
  • 34 POSTS
  • 1998 TOYOTA CAMRY
  • 2.2L
  • 4 CYL
  • FWD
  • 197,543 MILES
Where is the fuel pump relay on a 1998 toyota camry located.
Wednesday, April 17th, 2019 AT 11:40 AM (Merged)
HMAC300
  • 48,601 POSTS
The fuel pump relay is called a EFI relay and its located under the hood.
Here is a guide to help you test the relay
Here are the fuse and relay locations
Check out the diagrams (Below)
Cheers
TEXACA
  • 34 POSTS
Wow. Thanx that was a fast response. Thank you very much for your assistance. I was asking for a friend of mind. I'm not working on the car, a friend of his is. And, they were not sure where the relay was located. I had an general idea of where it should be. I'll forward your diagram to him. Thanx again, HMAC300
