The Knox sensor would set a code and you would likely hear excessive noise from the valves. The Knox sensor system enables the control module to control the ignition timing for the best possible performance while protecting the engine from potentially damaging levels of detonation. In essence, it changes ignition timing to meet the needs in the best possible way.
I'm not sure what kind of vehicle he has, but I've never seen the sensor shut fuel down.
SPONSORED LINKS
Tuesday, May 10th, 2022 AT 7:16 PM
