Fuel pump not working properly?
82,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
JKBROWN2
The fuel pump is not engaging when the ignition switch in turn to the start position.
Feb 23, 2023 at 11:38 PM
  • 110,251 POSTS
The fuel pump is mechanical and not electric (unless someone changed it). It won't pump fuel until the engine is turning.
Feb 24, 2023 at 1:38 PM
JKBROWN2
It's factory fuel injected, it has to be electric.
Feb 26, 2023 at 11:32 PM
  • 110,251 POSTS
You are correct. Sorry about that. They did have ones with mechanical pumps as well. It seems so odd to think of a 1978 that was fuel injected. It was very cutting-edge for the times.
Okay, when the key is first turned on, the pump should run for a couple of seconds. I believe that is where you are having the issue. Power is provided by a timed relay that energizes the pump for a short time. Once the vehicle is running, power is supplied via the starter solenoid.
Now here is my problem. Because of the model year, I have no wiring schematics to tell you where to look for the relay. It should be close to the fuse box. That is where I would start checking. Locate the relay and remove and inspect its connectors. Also, here is a link that explains how to test a relay:
See if you are able to locate the relays. Again, sorry I don't have the schematics or fuse panel legend.
Feb 28, 2023 at 10:18 AM
JKBROWN2
Follow this link for schematics:
www.speedyjim.net/schem/fi.htm
Thanks
Mar 2, 2023 at 10:09 PM
  • 110,251 POSTS
Thanks for the schematic. That is extremely helpful, and I know for sure it will help others in the future.
Take care and thanks again,
Mar 3, 2023 at 11:38 AM
