Code P2294, where is the fuel pressure regulator 2 located?
KIMOOOOOZ
  • 17 POSTS
I want to let you know I fixed it, yay. I changed the high-pressure fuel pump and now the code is gone.
Thank you so much for your help.
Thanks a lot.
Monday, October 23rd, 2023 AT 3:49 PM
  • 109,885 POSTS
Thank you for the update and you are very welcome. I'm glad to know the problem is resolved.
Please feel free to come back anytime in the future if you have questions or need help.
Take care of yourself,
PS: Good job!
Monday, October 23rd, 2023 AT 6:26 PM
KIMOOOOOZ
  • 17 POSTS
Hello. Sorry to bother you again but I want to let you know I bough VCDS software and the vag-com
For the P1612 code. But I don't know what to do to remove this code or to recoding the ECU.
Wednesday, November 8th, 2023 AT 9:58 AM
  • 109,885 POSTS
If you are programming the ECM, with VCDS, locate the activate ECM in "Guided Functions" operating mode under "Replace ECM. It should walk you through it. I believe that should delete the code.
Let me know what you find.
Wednesday, November 8th, 2023 AT 5:41 PM
