Fuel pressure regulator
155,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
KEVINSKUTNIK007
I am getting a code po172, running rich. I smell the fuel when starting. Open loop, checked fuel pressure and it is loosing pressure at a few pounds per minute. I am thinking that it is the fuel pressure regulator, but can not find it . Help.
Feb 11, 2018 at 3:45 AM
Good afternoon.
The pressure regulator is part of the fuel pump assembly.
what is the actual fuel pressure?
Also, check your air filter and also, a bad purge valve for the evap system will cause this rich condition.
does it have any codes set?
roy
Feb 12, 2018 at 5:36 AM
