Fuel or spark issue possibly
196,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
ROBC1985
  • 20 POSTS
I don't know exactly what's going on with it. I redid the head gaskets and have a code reading 8th cylinder second bank. But I replaced the 8th coil and it didn't change the code. i have replaced the fuel pump and filter new fuel lines. I'm rebuilding the truck and wondered what I should do next. Injectors or should I redo the other 7 coils or whatever else, my funds are very limited.
Here's a video of it running at idle, it drives better then it idles.
Aug 27, 2021 at 3:16 AM
The video did not attach if you can try it again. However, it may be too large if it is not uploading.
As for this issue, if you have single cylinder misfire on cylinder 8 and you just replaced the head gasket then we need to start with checking the compression on this cylinder.
Here is a guide that will show you how to do this:
I would run the compression on all the cylinders on that bank just to get a comparison but it is unlikely to be something that all cylinders are effected by like fuel pressure or even spark. It is going to be something specific to that cylinder like the injector, or spark plug, etc.
What I would do is instead of replacing parts, swap them to another cylinder on the opposite bank and see if the misfire jumps over there. Then you at least know what the issue is and can replace it accordingly.
Misfires are unfortunately sensitive things once you get past the common things like a plug or coil. So at this point we need to cover all the basic items first or we are going to chase our tail.
Compression would be the first thing I do because if that is not correct then nothing else matters.
Thanks
Aug 28, 2021 at 10:44 AM
