Check the fuel pressure. If it is too high it will cause the cylinders to flood with gas and foul the spark plugs. If the fuel pressure is too high, the small amount of time the fuel injector is open, too much fuel will squirt through the open injector because of the higher than normal fuel pressure. Another possibility is if it is always just the same few spark plugs that are gas fouling, maybe you have them fuel injectors dripping or leaking gas.
You could try a fuel injector cleaning.
I would lookup the fuel pressure spec, but I do not see a 1.6l engine listed. What is the 8th digit of your VIN number, that is the engine code. If it is a 3, 5 or P it is a 2.0l and if it is a Z, it is a 2.3l.
Mar 21, 2018 at 1:26 AM
