What your hearing may be the initial prime? When you first turn the key on, no crank, the pump will run for a few seconds, then stop if no rpm signal. Use a gage and check fuel pressure, check for injector pulse.
If your code reader won't work, check pin 16 at the datalink connector for voltage.
SPONSORED LINKS
Wednesday, April 17th, 2013 AT 2:20 PM
