1996-4.3l vortech-csefi system. W engine ,OBD ll, EDI system
On the last question it seems the fuel pressure regulator is suspect. Can the fuel pressure regulator be replaced without removing the air intake plenum ? can it be reached through the fuel meter body while
leaving the fuel meter in place or must the entire unit be removed to gain access ? Fuel pressure 61psi...falls of instantly...will not hold at all.
I am seriously considering conversion to carburetted. Edelbrock #2114 & 500cfm. comments? Am aware of complete change of much...perhaps not all, but most. Have a couple of questions if you consider viable.
Lets assume the auto will be off the road use only. that said , still must be tractable as if intended as every day driver.
You can see that this repair has been put off but now we are on the move. Thak you ,Jim jddingo
Jan 14, 2014 at 4:54 AM
