Fuel pump not working properly
  • 109,896 POSTS
What you're saying makes sense. Have you tried removing the black to inspect it for any corrosion or damage issues?
Friday, April 22nd, 2022 AT 6:58 PM
JERRY PLANCK
  • 14 POSTS
Joe, I cut the new ground. I spliced it into the black and white wire and tied it into the short black wire that's grounded to the frame, and it ran, so I believe I have an ungrounded frame. I have been ignoring the black wire since it just goes to the frame at the pump. So, I'm going to run new frame grounds and engine block grounds, and this should solve everything. Thanks so much for your input because I was going crazy.
Friday, April 22nd, 2022 AT 8:22 PM
  • 109,896 POSTS
You are very welcome. I think you are correct with your thoughts, and this should eliminate the issue.
If you have a chance, let me know if it takes care of the problems. I'm interested in knowing.
Friday, April 22nd, 2022 AT 8:39 PM
