Engine stalls
190,000 MILES • V8 • 4WD • AUTOMATIC
REBELYELL
Replaced fuel pump and after get it started finely will not stay running and when you turn the key off it still pumps fuel into the carburetor and it is a throttle body and also to let you know it is one of those vehicles that are a 1994/1995 model.
Oct 14, 2017 at 11:55 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Is the fuel pump still running when you turn off the key or are the fuel injectors actually dripping? If the later, then you will have to replace the fuel injector that is dripping. If the prior, just for now, try a new fuel pump relay and see if the fuel pump stops running when it should, when the key is turned off.
Oct 15, 2017 at 1:09 AM
REBELYELL
Yeah the fuel pump still runs because it just shooting out of them. I will try the relay. Thanks
Oct 15, 2017 at 1:13 AM
  • 55,721 POSTS
This sounds like you have a shorted injector or a injector driver that is stuck in the PCM can you unplug them to see if they still drip?
Cheers, Ken
Oct 16, 2017 at 6:56 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It is my understanding that those fuel injectors should not even have any voltage available to them from the ECM/ignition fuse at the red and white wires of the fuel injectors when the key is turned off, so regardless if the fuel pump runs still or not, the fuel injectors should still not even have power to them, nor a ground pulse, so they should not be pumping fuel when the key is off. unless of course someone jumped those injector red and white wires to a twelve volt source that is hot all the time, or that pink wire from the fuse to the red and white splice is shorted to twelve volts, either both red and white wires are shorted to twelve volts or the fuel injectors are in fact just dripping gasoline because they are stuck open because of dirt or whatever.
Oct 17, 2017 at 3:01 AM
