Check the fuel pump have some one turn the key while you go over to the fuel cap were the gas goes put your ear there and listen for a buzzing sound if you hear it thats the pump if not its not working.
Now if the pump is working does not mean its working fine, check the psi's on the fuel and make sure its in proper psi range.
Next check for spark. Take the coil spark plug wire off the cap (the center wire) and set it 1inch away from the center tip you removed it from don't hold it with your hand you don't want a shock. While watching have someone turn the key over and look for spark coming from the cap to the wire. If present you have spark if not theres your problem.
The cause is either timing is off or the ignition module is bad.
Hope this infor is helpful
Richard
Saturday, August 18th, 2007 AT 7:54 PM
