front end vibration 0-about 40 miles per hour release gas it quits after 40 it quits
150,000 MILES
THEDETOURE
Replaced both cv joints ball joints tie rods and motor mount changed tires and aligned still does it. motor seems to run fine too. help.....seems to be the left front doing it the motor mount was bad when i pulled it the 2 cv joints were bad when I replaced them ball joints were bad too I cant think of anything else the wheel seems to be tight enough when I lift the car up.
Sep 1, 2013 at 2:47 PM
DRCRANKNWRENCH
  • 3,380 POSTS
There is generally a center shaft underneath the drivers side opposite the transmission that connects the 2 CV axles. There are bearing in it that can go bad and cause vibration. If you replace a motor mount you must replace the whole set. This is because the others are fatigued and the new one will put more of a load on the old ones and they will fail quickly and then your new mount will fail. You should also replace the transmission mount.
Sep 1, 2013 at 3:29 PM
